What chairs do we get to Chatel from Morzine and what's the best way back on our Mtb
Start at the Super Morzine and look for a lift map they are usually free at the lift or you could get one from the tourist office.
[url= http://www.about-morzine.co.uk/winter/piste-maps/morzine-mtb-trail-map ]Morzine MTB Trail Map[/url]
On line maps can be a bit tricky. For example the map in the link above is out if date and at least two of the lifts on there aren't running. Its also for Led Gets, buts that's another matter 😀
Basically up the super morzine, then the chair. Ride the ridge to just below Avoriaz and drop down to Linderettes. Up the chaux fleurie chair and over into the next valley. There's a track that goes from the top of the bottom chair, slightly up to start, to Chatel. To get back you can ride straight back from the top via Linderettes. Start on the road then use the tracks back to the river valley.
Super Morzine lift
Zore lift
Ride/Push towards Avoriaz then PPDS route to Lindarets
From Lindarets it's the Chaux Fleurie lift to the top of the Chatel runs
Coming back we took the PPDS route down past Lac Montriond and into Morzine. Downhill all the way then flat once you're in Morzine
Don't go too far! The trail Starts next to the road junction not far from where you should meet the road
Thanks guys
From the loft car park the track to Chatel I'd uphill on the right hand side....
http://www.flickr.com/photos/27084274@N08/sets/72157630609141634/
nickjb - Member
DOH 😳
