Monster-crossing a ...
[Closed] Monster-crossing a Surly Krampus
6 Users
Just idle thoughts while at work...
I love my Krampus, but it has become a bit underused since getting my Stooge Mk4.
I've got most of the bits that would enable me to set it up as a single-speed Monster-cross - Salsa Woodchippers, V-Brake drop bar levers + a few sets of mechanical brakes, etc.
My only question is on a stem - would one need to go higher and shorter?
I normally ride it with swept back riser bars (Surly Sunrise) with a 45mm/0 degree stem.
Would I want something like a 70mm/30-40 degree stem?
What kind of saddle to bar drop should I be aiming for for comfy longish distance bimbling?
Just been looking for stems, but my Woodchippers are 25.4, and there are bugger all decent 25.4 stems around anymore!
Posted : 25/02/2021 12:32 pm
In short, yes to a shorter, higher rise stem as the Krampus is designed around flat bars. If you have lots of steerer, then you may get away with a short stem set to maximum height. I would say look to how Fargos are set up as a guide.
Oh and Cowchippers for the win. I have both types and reckon the Cowchippers are just as good off road but more comfy on the drops.
Sanny
Posted : 25/02/2021 12:48 pm
Shim?
https://www.sjscycles.co.uk/stems/gusset-handlebar-shim-254-318-for-standard-mtb-to-318mm-oversize-black/
Posted : 25/02/2021 12:49 pm
I've got a couple of shims, but if I'm going to buy a stem I'd prefer to buy the right size.
If I can't find anything in 25.4 I'll use one.
Posted : 25/02/2021 1:06 pm
 Bez
This is all very subjective, but I find drops work better with a longer position; trying to position the hoods in the place where you’d have your hands on a flat bar just doesn’t work for me. It’s a different riding style. When I’ve used the same frame with both drops and flats, I’ve had a longer stem with the drops.
Also I find that singlespeeds demand more stretch, because climbs mean standing up with a lot of force going through your back. So length and height both help here, in getting the BB-to-bars distance as high as possible.
At the end of the day, though, stems can be had for around a tenner or so, and are useful to have kicking about, so there’s no harm in just going for it and then tweaking it to find whatever position suits you: YMMV as always.
Posted : 25/02/2021 1:09 pm
Cheers for the advice 🙂
I was just browsing for Cowchippers, and then came across a good deal on some Pro Discover 30° Gravel Alloy Handlebars - they look similar to the Cowchippers in shape and flare.
Good review on Ridinggravel.com - https://www.ridinggravel.com/reviews-2/pro-discover-big-flare-bars-checkpoint/
Also bought a 35 degree, 75mm Ritchey stem, which should give me a bit more height at the bars.
Looking forward to some Monster-Truck Monster-Crossing 🙂
Posted : 26/02/2021 10:29 am
From idle thoughts to a Monster(truck)cross 🙂
Not the final bars, but I built it up with some Midge bars, and will fit the wider Pro Gravel ones when they arrive.
Took it out for a 30km spin today, and down some frankly inappropriate DH single-track. Was ace!
Posted : 28/02/2021 5:26 pm
Love a single speed krampus, tried gears and hated every second.
Posted : 28/02/2021 7:22 pm
 Del
you monster. 🙁
Posted : 01/03/2021 7:26 pm
you monster. 🙁
Ha! Joe loves it. That tells you all you need to know 😉
Perfect for some of my special 'light touch' trails.
Posted : 01/03/2021 8:05 pm
 Del
oh yes, yes it does. :shudder:
Posted : 02/03/2021 7:19 pm
