Mondraker help
[Closed] Mondraker help
11 Users
Can anyone help explain how to get these bolts out and what tool is required I just can't get them out, is it from the inside or outside and which direction?
Posted : 02/10/2016 11:10 am
I've had similar in the past on other bikes and they have been a male and female connection . One bolt does up into the other. So it's hold both at the same time and undo. They might be tight due to threadlock compound and or age.
Posted : 02/10/2016 12:00 pm
Try some boiling water if they're tight, may have be threadlocked.
Posted : 02/10/2016 12:04 pm
Thanks, I'll give the water a go, the ones on the outside seem to be very soft!
Posted : 02/10/2016 12:12 pm
Had similar bolts on my Nicolia bearing, they seemed to made of some sort of cheese.
Posted : 02/10/2016 12:54 pm
You are likely trying to turn it the one way. Both sides of that is one bolt, so to undo it using the outside socket turn it clockwise as you are looking at it.
Posted : 02/10/2016 1:02 pm
The black bit is the nut.
better explained in this photo
[URL= http://i64.photobucket.com/albums/h178/stevenpownall/37C26D69-5F02-403B-9EC2-614738753103_zpsyvmv4t07.jp g" target="_blank">http://i64.photobucket.com/albums/h178/stevenpownall/37C26D69-5F02-403B-9EC2-614738753103_zpsyvmv4t07.jp g"/> [/IMG][/URL]
Posted : 02/10/2016 4:47 pm
It's a normal rh thread - put an Allen key on both sides and unscrew anti clockwise from the capped head side. What he said basically..
It's a shit design - you'll need to thread lock everything when you re assemble as they'll all undo themselves otherwise. Once that black steel insert starts moving in the frame it quickly ovalises the soft cast seat of the ali frame and then you're dealing with a shagged out mess.
Posted : 02/10/2016 5:01 pm
Undo anticlockwise from the outside
Posted : 03/10/2016 10:02 am
Can turn the outside without them rounding off!
Posted : 03/10/2016 11:32 am
*Can't
Posted : 03/10/2016 11:33 am
If youve rounded the Bolt, your next option would be a Torx socket thats a good tight fit, hammer it in fully, also apply a bit of heat with a heat gun until its hot,or try a lots of hot water, use gentle force until you feel it turn.
If this fails your looking at drilling it out, but be very carefull not to damage the frame. HTH good luck
Posted : 03/10/2016 4:17 pm
Sorry I thought it was a which one/way to turn question. If it's jammed then follow above advice.
(I assume you've tried turning the inside clockwise? Or both inside and outside at once?)
Posted : 04/10/2016 10:28 am
Have this frame and I had this same problem and realised I was just being stupid! Because there is an allen key head on both the inside and outside of the bolt I thought you needed a key on both ends.
You simply need to put an allen key into the end facing out (so that bit you are pointing a)t and turn it anti clockwise, the oval shaped nut will stay in place in the frame and the bolt will undo. DO NOT put an allen key in both ends! The two heads are the same bolt so you won't move it!
If it helps explain I can go take a video of me unscrewing mine so you understand for sure?
Posted : 04/10/2016 11:16 am
Use a torq bit to hammer into the bolt head but don't sheer it off and leave hardened steel stuck in the head as it makes drilling it out very very hard...And yes I have done this...
Posted : 04/10/2016 9:44 pm
[url= http://www.silverfish-uk.com/DocumentHandler/32837 ]http://www.silverfish-uk.com/DocumentHandler/32837[/url]
Posted : 04/10/2016 10:49 pm
