Mobi washer faulty?
Mobi washer faulty?
5 Users
2 Reactions
 jedi
My mobi washer pulses and it has started only recently. Had it over a year. Any idea of a fix?
Posted : 18/02/2024 6:23 pm
I found that I had to turn it on with the hose connected but without the gun until water came out then attache the gun.if I didn't it would pulse like there was an air lock
Posted : 18/02/2024 6:52 pm
No experience of that make but just repairing my 25 year old Karcher that had the same symptoms. It was a leak on the low pressure side that required some parts that I got from E spares. It may be that your washer isn’t getting enough pressure from the supply side?
Posted : 18/02/2024 6:55 pm
Pulsing indicates poor water supply to the pump. First thing to check is the strainer/filter on the hose inlet. That’s certainly the case on my karcher,
Posted : 18/02/2024 6:59 pm
 jedi
I'll try this first tha ks
Posted : 18/02/2024 7:38 pm
@jedi on the mobi also check the hose it's directional .for the valve .so check you've got the right end to the machine v gun
Posted : 18/02/2024 8:18 pm
 jedi
I didn't know that cheers I'll check
Posted : 18/02/2024 8:20 pm
check the hose it’s directional
It is? I just plug my Mobi in and use it, I've never experienced it pulsing.
Posted : 18/02/2024 8:23 pm
Mine is one of the original versions before crc bought mobi so there may of been changes I guess.
Mine is well over 10 years old and only ever needed to replace the gun
Posted : 18/02/2024 10:15 pm
