mix'n'mat...
[Closed] mix'n'match headset brands - will i die?
7 Users
i want to reduce the stack height on my current ride.
i am limited to just a few options as the frame takes a tapered intergrated is42/52 headset.
my choices are fsa (which i have at the mo), cane creek or superstar.
my current top cap is 15mm and i want to get down below 10mm. i don't really see the need to fork out for a full headset, so i am thinking of just buying a top set of bearings with low-stack top cap.
as far as i can see, even if i mix cane creek with fsa, the fact that they are operating at different ends of the headtube shouldn't make any difference, and therefore i will not die.
is this true?
Posted : 20/01/2014 2:38 pm
Makes sense to me.
Posted : 20/01/2014 2:43 pm
They're just ways of holding a little tube inside a big tube. Can't see a problem.
Posted : 20/01/2014 2:47 pm
all they are doing is carrying the bearings. Should be no issue at all.
Posted : 20/01/2014 2:49 pm
That found be fine. For other options also check out, Hope, as they have some low stack heights
Posted : 20/01/2014 2:54 pm
i'm sure someone will point it out if you ever post a photo on here.
But technically, all good to do that.
Posted : 20/01/2014 2:56 pm
The upper bearings of my headset collapsed (5 minutes into an enduro last year 🙄 ) and I replaced just the upper bearing & cup with a Hope one. No problems at all
Posted : 20/01/2014 3:20 pm
hope don't do is42 otherwise i'd be there like a rat up a drainpipe.
Posted : 20/01/2014 3:40 pm
