Mixing XTR 11 speed...
[Closed] Mixing XTR 11 speed and XT 10 speed components
3 Users
Maybe the collective STW knowledge can help me out here. Is it possible to run the following set up:
XT 2 x 10 cranks
XT 10 speed front & rear mech
XTR 11 speed rear shifter
XTR 11 speed 11-40 cluster
Shimano 11 speed chain
As I understand it the 10 speed rear meach has the same throw as an 11-speed one, so this set up should work, but someone might have some rear world experience on this
Posted : 12/06/2015 9:38 pm
 DeeW
From what I've read you are right. But zero experience of riding it.
Posted : 13/06/2015 7:07 am
Parallelogram is different on 11 spd mechs to track closer to the 11-40/42 spread. On a 10 spd you'd need to use the b-tension screw to pull the guide pulley away from the larger sprockets leading to poor shifting elsewhere.
11 spd XT 11-40 cassettes and GS rear mechs are confirmed as being due 1st week in July at Madison - just get them - still cheaper than XTR cassette on it's own.
Posted : 13/06/2015 8:30 am
