I received a small parcel from CRC today. One of the items was Muc-Off wet lube, the big bottle. I unscrewed the cap, removed the foil from the top of the bottle...
... and then I realized that the cap is damaged... Its nose (which should have a thread and closing cap) is missing (snapped off)! 😡
I've checked the box - it's not there... So now I'm left with a big bottle of wet lube that I can't close properly, not to mention taking it with me for a ride. 👿
I've got a bottle with a bit of Wet Lube in it (Finish Line), but it's smaller - can I pour some Wet stuff in it?
#firstworldsproblems
I've got a bottle with a bit of Dry Lube in it (Finish Line), but it's smaller - can I pour some Wet stuff in it?
You take your lube out for a ride?
My rucksack is like a mini workshop... 8)
why not just contact crc and get them to send you another bottle ?
Presubably you mean another bottle of dry?
IME mixing them on the chain (byt not cleaning it propelry first) gives the worst of both worlds, the solvent won't evaporate quickly enough from the dry lube so you end up with a really thin wet lube.
