Mix n match brake e...
[Closed] Mix n match brake equipment?
5 Users
Iv set up my new Formula Rx front brake using a Shimano 180mm center lock rotor and shimano 180mm IS to post front brake adapter as these are bits I had lying around.
All is well and the brake works fine but I as surprised to find that in order to line the calliper up I had to use quite a lot of thick washers and shims between the fork and the brake mount.
I was surprised since I assumed everything (forks, hub, rotor, adapter, caliper) would be built to standard sizes.
Am I risking problems using the washers - there is probably about 2-3mm worth and the threads of the bolts do not completely engage the threads of the adapter (probably about 3/4 engaged).
Posted : 29/10/2013 1:50 pm
Better shimmed to fit, than just left as bought, IMHO.
Posted : 29/10/2013 1:56 pm
Should be fine.
Speaking of mix and match, I've often wondered if I could mix lever and calliper of different manufacturers. E.g. a Hope lever and an Avid calliper. I guess it would depend on displacement of the lever piston being about the same. Anyone done this?
Posted : 29/10/2013 2:01 pm
Piston displacement and reservoir volume are the only variables I can think of in terms of comparability.
Posted : 29/10/2013 2:24 pm
wouldn't have thought reservoir volume mattered much, its all about fluid displacement volume.
oh, and fluid used - don't mix mineral oil (e.g. shimano) with dot 4 (e.g. avid)
Posted : 29/10/2013 2:36 pm
I'd definitely fit longer bolts!
Also- I've made a couple of pairs of frankenbrakes in the past. You may also need to consider hose diameter and end fittings. Lots of kits available for this though.
Posted : 29/10/2013 2:41 pm
My thinking was....
If you increase the size of your slave piston which could be the case if you fit a different caliper, the difference in volume in the system between new pads and dead pads will be greater - meaning a larger volume reservoir is required.
Posted : 29/10/2013 2:44 pm
