Mix and Match Disc ...
[Closed] Mix and Match Disc Calipers / Levers
4 Users
Looking for new brakes, have been considering Shimano saint. Now I have seen on wiggle that the calipers and the levers are sold seperatly. Does anyone know if I can use the levers from my formula brakes on Shimano Calipers? Part of me thinks "No way, there must be some sort of difference", the other part of me thinks "Why not...."
Appreciate any info.
Posted : 31/05/2011 10:55 am
[i]"Why not...."[/i]
Why?
Shimano are all compatable with each other, I believe.
why you'd want to risk running parts across manufacturers where there's no standards for the amount of movement in a caliper for a certain lever throw or even any standard on what they fill the things with is beyond me.
Posted : 31/05/2011 10:57 am
Formula use dot fluid and shimano use mineral.The internal seals are not compatible with different brake fluid.
That and leverage ratios-how much oil the lever displaces compared to the caliper (piston diameter vs stroke).
Posted : 31/05/2011 10:59 am
- Not a very patronizing answer......
This is why I asked the question. Sometimes marketing leads us to beleive this is not possible, I always like to question why before spending out something when I allready have a good working pair just in case something is possible.
Posted : 31/05/2011 11:05 am
Thanks Rorschach... that makes sense.
Posted : 31/05/2011 11:06 am
I of someone on here who has managed to bodge Hope levers with Shimano calipers for the fun of it, by swapping some seals around.
But different leverage ratios and fluid types normally mean its not possible.
Although all Shimano stuff is compatible, BUT Im not sure about the latest 2011 Deore / XT / XTR yet.
Stick to same stuff if you can.
Posted : 31/05/2011 11:32 am
