Minion on flows
[Closed] Minion on flows
6 Users
Running with tubes but I have loads of issues getting the tyre onto the rim. Snapped a plastic tyre lever.
Should I just force them on with metal levers or am I doing something wrong? Don't like resorting to forcing things. It's getting annoying now as I'm changing the front tyre quite regularly.
Posted : 27/12/2010 8:00 am
 rlt
Been running single-ply 2.5's on flows with no trouble (tubeless). What size/type are you using?
Posted : 27/12/2010 9:57 am
 awh
I've had a mix of tubeless Minion, Advantage and Ardent on my Flows. The fit is tight but I wouldn't say I'd got to just forcing them on. Apart from making sure the first bead is right in the centre of the rim when fitting the other I can't think of any special tricks.
Posted : 27/12/2010 10:05 am
No problems here with Crossmark LUST, Ardent LUST, Ignitor LUST and single ply wire bead Minions.
All used with yellow tape. The minions were a pain to seat but sorted by leaving overnight with a tube installed to fully seat the bead on one side. Never needed levers to get any of these tyres on.
Posted : 27/12/2010 10:43 am
If you haven't done so already, you could try using some neat washing up liquid on the tyre bead. I've found this sometimes helps with really awkward tyre/rim combos.
Posted : 27/12/2010 10:55 am
+1 washing up liquid
Posted : 27/12/2010 11:47 am
