I'm on the look out for some handlebars with a sweep greater than the 8-9 degrees that is fairly common. I think 12 degrees would be fine. I've come across SQLab and Syncros but I'm also looking for other options. Bonus points if they're available in 35mm as that would avoid a stem change.
Syntace also do 12degs. Not sure about 35mm though.
Ah - I meant Syntace and not Syncros 😶
On One Fleegle Pro on my bike. They are the only one I've found other than SQ labs.
Salsa do 11 deg if you can find them.
I have a set but in 31.8mm diameter.
Are those Rustlers - and would you be prepared to part with them?
17 degrees is the goldilocks angle.
<span style="font-size: 0.8rem;">Swept back enough to be comfy but not too swept to feel odd.</span>
They are Salt Flat 2s
750mm width.
I might be interested if scotroutes doesn't want them.
Fleegles are good. I think the 25.4 bar/stem helps with
comfort, too
Titec Flat Trackers are only 700mm but feel good with an 11 deg sweep. £21 here -
https://www.sjscycles.co.uk/handlebars/titec-flat-tracker-handlebars-11-deg-318mm-clamp-700mm-black/
Stooge Moto, but they're 17 degree, 31.8mm only and are rarely in stock.
Thanks nairnster. I was after something with a bit of rise too.
I might be interested if scotroutes doesn’t want them
Go for it!
Thanks for all the other suggestions too. I'm not sure that 16/17 degree bars will work well on a AM full-suspension bike so still prevaracating.
