I've never had these. Is it possible to convert a standard set to fit a fatbike? I'm assuming the axle is bonded/permanently fixed to the NDS.
you can buy them with a longer axle but I'm pretty sure it's fixed
That's what I assume, I was just hoping someone was sure.
I'll have a look in the morning if you want, but
[url= http://www.middleburn.co.uk/x-type-fitting-instructions.pdf ]The Left crank arm and bottom bracket spindle are assembled in our factory as one unit and is designed not to be disassembled[/url]
Well, you're not meant To be able to completely remove the axle. However, it is possible as I've done it on my old ones. Will need a bit of effort and a breaker bar on the end of the hex key but yes, can be done.
why did you do it flange - can you buy replacements ?
Anyone else tried this?
Middleburn will swap the axle, its mentioned in the thread here: http://singletrackmag.com/forum/topic/middleburn-rs8-x-type-2
