middleburn 46/30 gr...
[Closed] middleburn 46/30 gravel cranks
5 Users
i'm thinking about a 46/30 or 48/31 to replace the 50/34 ultegra on my gravel bike. what middleburn setup would provide that ?
hollowtech preferably or possibly square taper (what spindle length? )
just wondering if there's an option that doesn't need a new front mech
Posted : 05/04/2020 2:03 pm
From memory, they launched a 30/46 chainset just before going bust, I've since looked on the BETD site to see if they were resurrected but not found anything. If I'm wrong I'd appreciate a link as I could be interested. My solution is to run 30/46 oval rings from Absolute Black on Shimano 105 4 arm cranks, I'm not particularly weak of leg but prefer to spin up the steep loose gravel climbs found here in Spain.
Posted : 05/04/2020 3:02 pm
thanks pistonbroke. do you feel a tangible difference with the oval rings?
Posted : 05/04/2020 6:09 pm
There's 2 reasons for them being oval, the bcd of compact cranks is usually too big for 30t rings but on the Shimano 4 arm it just fits using special low profile bolts. Second is it seems to give a smoother transfer of power so reduces the tyre breaking grip on loose surfaces with narrow tyres.
Posted : 05/04/2020 6:18 pm
I'm in the process of gravelizing my old CX bike and ordered up obe of these
https://www.sjscycles.co.uk/chainsets/170-fsa-tempo-adventure-11-speed-double-chainset-4630t/
Posted : 05/04/2020 6:39 pm
Spa cycles will do any ratios you want. Mine is 40 28. Shifting still great with original front mech
About £80 with bb
Posted : 05/04/2020 10:09 pm
If you need a new home for your ultegra cranks, I'm after some 50/34 175mm.
Posted : 07/04/2020 2:03 pm
someone very kindly sent me a private message re cranks, it seems to have disappeared off the message page/ or the page doesn't load. if you see this post id be grateful if you message again, thanks
Posted : 11/04/2020 9:18 am
