Middle ring skips t...
[Closed] Middle ring skips to granny
4 Users
Advice please!
When in middle ring and either of the bottom gears at the back (the big rings on the cassette - I can never remember if that is top or bottom...) the chain skips from middle to granny ring.
Is this a front derailleur issue? Any thoughts? FWIW chain and cassette are newish, and middle ring fairly so.
Posted : 22/07/2011 9:13 am
yep, thats most likely front derailleur, probably could do with a bit more tension on the cable, which you can use the barrel adjuster on the shifter (turn it anti-clockwise 1/4 turn, try again then repeat) HTH
Posted : 22/07/2011 9:24 am
ah, ok. I put new inner & outer cables on lot long ago, so it's probably stretched a bit
Posted : 22/07/2011 9:35 am
 SiB
anti clockwise as you're sitting on bike or facing it?
Posted : 22/07/2011 10:18 am
looking at the shifter along the cable.
Posted : 22/07/2011 10:22 am
