Microshift road shi...
[Closed] Microshift road shifter dropping too many gears? Help.
3 Users
My son's road bike has Microshift gears, but it's just started dropping about 4 gears on the cassette with a single push of the trigger.
I've had the shifter apart and when the cable is out it seems to shift ok, I put it back together  and set up the gears again with as little tension as I could and it shifts to the bigger cogs fine but push the trigger to go down the cogs and it jumps about 4 with each push.
It just seems like there's far too much tension in the cable but I can't set it up with any less.
Any ideas????
Posted : 27/08/2019 11:26 am
Just thinking about it, could it be the rear mech that is pulling down too hard and causing it to shift too many gears?....
Posted : 27/08/2019 12:02 pm
Still haven't sorted this out any ideas anyone??
Any thoughts much appreciated.
Posted : 20/11/2019 11:15 am
Usually a long blast of WD40 in every crevice, working the shifter as you do it brings them back.
There will be some crud in there / unlubricated pivot or something
If that don't work it will likely be worn out and replacement time.
Follow the WD40 up with some 3 in 1 spray oil or something that will hang around longer than a couple of days.
Posted : 20/11/2019 1:03 pm
Nice one thanks, I'll give that a go. I did take the shifter apart as much as I dare but i'll have it off again and squirt everything thoroughly!
Posted : 20/11/2019 1:14 pm
yeah you need to wash out all the ratchety gubbins, blast the wd40 with the tube attached from as many angles as poss whilst working the shifter.
Posted : 20/11/2019 4:03 pm
funny i had a similar issue with my bike last week end - not same setup (SLX rear mech) but the issue was routing and attaching the cable end to the rear mech the wrong way!
Posted : 20/11/2019 5:12 pm
Cheers Gilles, I'll check that out as well then.
Posted : 20/11/2019 5:54 pm
