Sounds like the Rock Shox MegNeg would be ideal for a single pivot (Orange, Starling, etc.) bike. Am I right? Experiences? Faff to get it nicely set up?
Bueller. Bueller. Class? Anyone?
Don't know, but interested.
What are you trying to change !
If your frame has linear suspension then i dare say a megneg should do some good in tuning in your travel to be a bit more progressive through the travel, and you also have the adding of tokens to tweak it more, can't see a negative from this type of modification if a little progression through the stroke is what you're after, same with sticking a progressive spring on a coil shock, or tweaking tokens in most air shocks.
I put a Vorsprung Corset, which is basically the same thing i think, on my orange five29 and its great.
Improved all over.
Better small bump complicance
Better support (because you use higher pressures (20% iirc))
