Mega TR knocking
[Closed] Mega TR knocking
5 Users
After lots of hunting round through forums im still at a loss as to whats causing a knocking noise on my mega tr. It happens whenever i compress the rear suspension.
So far i've changed the bearings in the frame as well as the chainstay bushes, changed rear wheel bearings as they had play and thought could be the culprit. Had the shock full serviced as well as changing the shock mounting hardware (original hardware wore and developed sideways play very quickly).
Any other Mega owners have this issue and solve it?
Posted : 30/10/2015 12:06 pm
Does it have internal routing for the cables?
Posted : 30/10/2015 12:14 pm
There was an issue with some spacers in the rear suspension. Common problem and was a warranty replacement (the spacers) if you asked CRC or wherever you bought it from
Posted : 30/10/2015 12:19 pm
No, no internal routing. I saw that thread and the mention of an issue with the chainstay bushes/pivot. CRC did send me replacement sleeves/bolts but seemed identical to what came out of the frame, it was a while ago i took it apart and i dont remember if it had the "top hat" spacers. Ill have to take it apart again and check.
Posted : 31/10/2015 12:54 am
Nukeproof via crc are currently putting together a full set of bushings/bearings for my 2014tr. I'm sick of the ****ing thing creaking under pedal load!
Posted : 31/10/2015 6:38 am
Never really had a problem with creaking, just knocking on mine.
Posted : 31/10/2015 3:01 pm
i dont have knocks on mine, but the headset creaks badly
Posted : 31/10/2015 3:41 pm
