So what length seat post are you running? I currently have a 125mm drop post fit and there is approx 70mm under the collar of the reverb. I was hoping to fit a 150mm post as I have room above the seat clamp. However I can only find the 150mm in a 480mm length. Is anyone running a 150mm post? I have an inside leg measurement of 30" if that helps
170mm on mine with the same size legs as you.
Post is maybe a couple of mm higher than I’d ideally like, if I switched to 170mm cranks as I’ve been meaning to it’ll be fine.
I’d say 150mm you’ll be fine.
I’m using a 160mm bikeyoke revive on my scout, I’ve also got a 30” inside leg and I’ve got probably 40mm of post sticking out under the collar if not more.
Thanks for the replies. I forgot to mention that mine is the 2017 version if that makes a difference.
My scout is 2018 and from having a quick look at the transition website your seat tube is 9mm longer than mine is.
If you dont want to stick with reverb and as recommended to me earlier, the oneup dropper is what I have just ordered in 150mm.
Ashweee
What is the overall length of the dropper you have ?
I have tried a longer drop post but it would not insert far enough.
