Mechanical - removi...
Mechanical - removing gxp crankset
7 Users
Hiya,
Trying to remove an old X5 double crankset from my commuter.
8mm, through the self extracting crankbolt, anti clockwise, right?
Won't budge.
Trying hitting the Allen key with a rubber mallet, no effect.
Don't have very strong hands (carpal tunnel), any ideas?
Cheers Alex
Posted : 05/08/2022 4:15 pm
 Yak
Yeah. Don't hit it though. Put a longer bar over the allen key for leverage. It shouldn't take too much force.
Posted : 05/08/2022 4:21 pm
2' long breaker bar and stand on it while also standing on the other pedal to stop rotation.
It shouldn’t take too much force.
Posted : 05/08/2022 4:22 pm
 Yak
^ It's gxp, not dub!! Dub needs all that + a goat sacrifice. Gxp needs a firm tickle.
Posted : 05/08/2022 4:26 pm
+ a goat sacrifice.
Will try that. Sounds less painfull than pedal pins to the shins.
Posted : 05/08/2022 4:28 pm
I’ve always found GXP and DUB take the same amount of effort to crack the bolt off.
You need a bigger lever than an Allen key either way. I usually use a breaker bar style lever and most of the time it then doesn’t need hitting / standing on.
Wouldn’t hurt to soak the bolt in plusgas / any other equivalent anti seize type spray for a few hours first.
Posted : 05/08/2022 4:32 pm
Supporting the Allen key/ socket attachment where it comes out of the bolt (eg a car jack and a block of wood) helps prevent it coming out and mashing the bolt. Getting the frame standing vertical and the Allen key nicely supported is a faff, but means you can stand on your extensiom/ breaker bar with more confidence, indeed bounce up and down on if needed.
Posted : 05/08/2022 6:40 pm
Lefty loosey, as above a longer lever should do it as they're on quite tight. Can you slide a pipe over your allen key if you don't have a longer ratchet/breaker bar
Posted : 05/08/2022 7:19 pm
As above, using a breaker bar makes a huge difference. To stop the crankset rotating, I sometimes take off the non-drive side pedal, and slot a 2ft length of 2" plastic pipe over the crank. Works a treat.
Posted : 05/08/2022 8:45 pm
Thanks learned sages. I shall procure a breaker bar tomorrow.
A whole new world
Posted : 05/08/2022 10:54 pm
