Mechanical disc bra...
[Closed] Mechanical disc brakes: MTB/Road cable pull question
7 Users
I know, for example, BB7s are specified as mtb or road specific, to do with the different cable pull.
What would happen if I fitted road callipers to a mountain bike, or mtb callipers to a road bike?
Posted : 10/01/2013 9:31 am
shimano mtb caliper worked on my road levers ok. changed to bb5 road, and other than having to adjust for pad wear slightly more often i really can't tell the difference.
Posted : 10/01/2013 9:33 am
mtb calipers on a road bike is horrible ....
i had this on my roadrat - it worked to a point but the lever just didnt pull enough cable and invariably i ended up wit the levers almost touching the bars to stop. the pads could not be any closer without rubbing but needed setting to this point often(weekly) or i ended up pulling to the bars with no power.
fitted roadie bb7s from ken_sheilds and it now works wonderfully and ive yet to adjust the pads after 2 months of riding.
Posted : 10/01/2013 9:40 am
So, if you fitted road calipers to MTB levers, you could have much more pad travel and set them further away from the discs for greater crap avoidance and/or avoiding wobbly-disc-induced rub. And you have increased modulation tweakyability (if running SD levers)?
Posted : 10/01/2013 9:46 am
I've got MTB BB7's on a Cotic X. they work. I can stoppy the front.
the best thing i did was to use a solid cable (nokon sp) on the front, much better feel. shame the rear has got full length outers.
Posted : 10/01/2013 9:47 am
I put a rear road caliper BB5 on the MTB it had no stopping power at all.
Posted : 10/01/2013 9:57 am
If you had some old MTB canti levers, they'd work with road caliers.
Posted : 10/01/2013 9:59 am
