Hi All
2 things:
Maxxis HR2 - Exo 3c blah blah blah. Done less that 600 miles on it and a knob cracked to the extent it made a hole in the tyre! Is this normal? I'd noticed the knobs were cracking a little after a few rides.
Then went to put a tube in as clearly the sealant wasn't doing its job and all I found inside the tyres was some sealant boogers, is this normal, they were hardly liquid to fill a hole!
How long was the sealant in for?
Mincing along towpaths no, rampaging down the alps and heavy braking/cornering, yes
After a few weeks no, after a few months in hot weather, yes
So basically, no or yes, depending on the circumstances, give us some more info!
CO2 will do that to stans fluid too.
Also if the original installer was tight with the amount of sealant when setting them up, a small quantity will dry up quicker
50% xc type riding 50% alps and BPW
Had the bike for 3 months
Sound like I should check my sealant more often then!
Yeah, 3 months of hard riding on the summer will use up your sealant 🙂
Also, the enlarging hole/s will have used up sealant, possibly without you immediately noticing.
Some makes of tyres soak up the sealant more than others, ie continental uses loads even after they are sealed, where as schwalbe barely seems to need any.
