Maxle QR loose - ne...
[Closed] Maxle QR loose - new axle?
3 Users
The clamping lever on my maxle is now quite loose, scews in fine but the clamp feels like either the cam or the eye has worn and is a bit floppy, is there a fix for this or is it new axle time (which would be upsetting)?
TIA
Posted : 21/03/2016 11:07 am
have you tried doing up the little allen headed screw inside the lever a bit?
Posted : 21/03/2016 11:08 am
There's a few different designs of maxle. I suspect you have the hidden grub screw one as the older one is a bit more obvious on how to adjust it. Either way it should be adjustable.
Front is the same
Posted : 21/03/2016 11:12 am
Coolio, will have a butchers when I get home tonight.
CHeers
Posted : 21/03/2016 11:15 am
