Am i doing something wrong?
Find my front (20mm) and rear (12mm) loosen on a regular basis, almost every ride. Something like a quarter turn. Fairly old frame and forks (2011/12).
Never had this issue with QR.
have you adjusted the tension so the lever is tight when it rocks over?
What del said. On newer ones there is a little grub screw and older ones it's more like a traditional qr. Closing the lever should be fairly tough and leave a small red mark/indent on your hand.
Erm, you mean actually look at it to see what could be done? Well no, but I will be shortly. Does it have some sort of screw to adjust tension?
EDIT: Not tough on either to tighten so some fettling tonight, cheers guys.
There's a bunch of different versions tbh, the latest one is a sort of push-to-adjust thing on the front, toolfree, quite clever tbh. The rear on mine is an absolute pain in the arse.
