Does anyone know where I can get a replacement nylon freehub bushing for my Ksyriums? I can see Hub Doctor in the US has them, but was wondering if you can get them in the UK?
Any info/advice would be appreciated.
Cheers.
Try the Pedal On website. Also and LBS stocking mavic wheels should be able to order one in.
I bought one from the states via eBay a couple of years back, worked fine, turned up promptly, there are a couple of sellers doing them in standard and oversized versions. I've never seen a UK option and Mavic, as far as I'm aware, only sell the complete freehub. Changing the bushing is simple enough btw.
Have been told by mavic they only do hub bodies not the yellow ring on its own
Thanks guys, called Pedal On, and Ebay from the USA it is then. Cant get them in this country.
That's correct orangeboy,
Mavic don't supply them seperately.
I have fitted the ones from the state's, you just need to make sure you order the correct size as they do some slightly oversized ones for worn hubs.
