Mavic Ksyrium elit...
[Closed] Mavic Ksyrium elite.... brake juddering...
5 Users
As above, brake juddering (front wheel) more noticeable when slowing right down. On closer inspection the wheel stops spinning at the point where the rim is joined. I've gently rubbed the rim with a sanding pad, but still the same problem. Nothing to see that looks to be at fault, eg cracks, dings, etc
Got the wheel off fleabay a couple of months ago, first time I've been out on it. Is it going to explode on me? I'm a big lad! Will it eventually sort itself out? Should I get a new rim?
Thanks for any suggestions...
Posted : 19/09/2016 8:47 pm
Have one that does the same. As Mavics wear down you will see a wear indicator appear. If you can't see it, don't worry. I also have a set that don't as well. I am not big.
Posted : 19/09/2016 8:53 pm
Thanks for that, I don't think it's something that should be going on with what are quite an expensive wheel!
Posted : 19/09/2016 8:57 pm
@TiRed, can you elaborate a bit more on the wear indicator?
I've got a set of 2010 ksyrium elites with 10k miles, and have been wondering how i tell when they are done.
Posted : 19/09/2016 9:10 pm
Try putting a bit of toe in on the pads - this stopped the juddering on my rim brakes.
Posted : 19/09/2016 9:51 pm
little dot appears on the braking surface - normally opposite the valve. I assume same for these rims
Posted : 19/09/2016 9:58 pm
