Mavic EN 521 rim - ...
[Closed] Mavic EN 521 rim - can it go tubeless with Stan's yellow tape?
6 Users
If I run UST tyres and apply the yellow rim tape and use Stan's olympic valves, will it work? I've got a choice of the EN 521 or the XC 717 and I want to run 2.2 + UST tyres. The width and profile of the EN 521 looks like it's best for the job. Any experience of doing this? Ta.
Posted : 02/02/2011 9:03 am
I've got my 521 tubeless with a bmx tube worked great first time and went up with a track pump
Posted : 02/02/2011 9:05 am
Yes, ghetto is an option, which would work for both rims, but ideally I'd like to set it up with the Stan's system.
Posted : 02/02/2011 9:13 am
The stans system is just gheto with a £30 price tag, the yelllow tape is yellow tape, the rim strip is just aa thick BMX tube cut to fit.
The DT/eclipse system is a bit more technical.
My EN321's were fine with both gheto and stans.
Posted : 02/02/2011 10:29 am
Can't comment on the tubeless, but sounds like EN521's are overkill for what you want. They are 21mm wide which is more than you need for a 2.2 tyre, and are 25% heavier than 717's.
I run 521's because I abuse them and use 2.35 tyres, but wouldn't want them for XC
Posted : 02/02/2011 10:39 am
Trailrider Jim, I've got an unused 10m roll of stans 21mm tape if you want it, £8 posted
Posted : 02/02/2011 10:49 am
3M crossweave tape does everything Stans tape does at a fraction of the price
http://cgi.ebay.co.uk/1-x-ROLL-19mm-x-50m-Crossweave-Reinforced-Tape-/180337800112?pt=UK_Packaging_Materials&hash=item29fcf873b0
I've taped up dozens of wheels with no problems, even on 90psi road tubeless
Posted : 02/02/2011 10:51 am
