Mavic crossmax sx b...
[Closed] Mavic crossmax sx bearings
4 Users
Hi all,
I have a set of 2013 crossmax sx wheels (the white ones), after just over a year of fairly heavy use I need to change the bearings in the rear hub and freehub.
Does anyone know the bearing numbers for these? The hub bearings are listed on mavic site as m40076, what does correspond to in bearing numbers?
I've not been able to find any info about the freehub bearings at all, so any info appreciated!
Also, if anyone knows where I can get said bearings near Halifax that would be great - moved here last week and haven't got a clue where anything is yet!
Cheers!
Posted : 04/08/2014 11:18 am
Possibly
6903
30mm 17mm 7mm
Posted : 04/08/2014 11:53 am
Rear hub is 6903 and the freehub is 6803.
The freehub ones are not meant to be changed but you can. The bearing number above is for the XX1 freehub but I can't see it being any different.
Posted : 04/08/2014 12:10 pm
I changed the freehub bearings but it was very difficult to press the inner bearing in. All the others were easy enough.
Posted : 04/08/2014 1:17 pm
