Mavic Crossmax 135 ...
[Closed] Mavic Crossmax 135 * 12 adaptors - where to get?
4 Users
Hi all,
The title says it all. I've tried googling, there are some 142 * 12 options, but not 135 * 12. Apparently they're either too old or always come stock so not much out there.
Wheels are 2010.
Posted : 01/03/2013 1:49 pm
Which crossmax?
On the older SX you just pull out the QR ones and they are ready for 135x12.
Posted : 01/03/2013 1:51 pm
The 2010 ones - are they 'older' or not?
Posted : 01/03/2013 1:53 pm
I have 2009 Crossmax SX,
As above, they come come with a 135x12 setup, including adapters for skinny QR already fitted (mine did).
They are just little plugs (about 10mm deep) with a rubber band/seal part way down. I poke mine out using the end of the QR (gently) when i need too. There's 10mm axle adapters available too.
EDIT: think the 2009 and 2010 were pretty much the same, the 'new' ones are post-2011 i think.
More tech info & the parts diagram from mavic is on the tech docs website: http://www.tech-mavic.com/tech-mavic/technical_manual/data/logon.php
Username: mavic-com
Password: dealer
Posted : 01/03/2013 1:55 pm
Pretty sure they will be like that. Mine might even be 2010s. Design went unchanged for a few years anyway IIRC.
Posted : 01/03/2013 1:58 pm
That'd be ideal, thanks.
They're grey rims and white hubs.
AFAIK there was a change in rear hub design around 2008/09, they went from grey hubs (circa 08/09) to the new design white ones (10/11) so hope it applies to my version 🙂
Posted : 01/03/2013 2:04 pm
Pull the QR adaptors out. Job done; conversion complete. An allen key in the hole and hooked on is ideal for this
Posted : 01/03/2013 2:27 pm
Thanks!
They come with 142 * 12 adaptors on, I assume it just means I'll need to take them off and that's it?
Thanks guys for the advice. Greatly appreciated.
Posted : 01/03/2013 2:44 pm
