I'm shortly getting a rear wheel built up and considering these, partly just to match my Mavic rim up front
It's for a gravel bike and needs to take 32-50mm tyres (tubeless), so I'm looking at 20-23mm width and hoping for something light-ish
I can find zero info on the above, not even certain about the weights as Mavic don't list on their site
Anyone got any experience with either?
I may just end up going with DT Swiss something, but the ones I'd want aren't in stock with the builder
https://www.chainreactioncycles.com/mobile/dt-swiss-r-500-disc-brake-road-rim-22mm-/rp-prod168810
Depends how tough your gravel is but the above fits your criteria.
@nixie yes, I was thinking the R500 may make the most sense. Quite heavy though at 495g.
I'd rather something closer to 400g, if possible. I was considering the DT XR331, which is 380g although only 20mm internal and that's almost suspiciously light.
SJS is where the wheel is being built, as it's onto a Rohloff hub, which they've just serviced. So I'm a bit constrained by their stock (which doesn't include, say the XR361 or XM401, both 22.5mm internal)
Pretty sure my mate has just built up 2 A1022's onto XT hubs for his gravel bike - they have turned out to be a fair chunk lighter than the Aksiums that were fitted before. He's managed to fit a road 11 cassette to it as well be getting a couple of mm machined off the big sprockets' spider (hadn't realised MTB cassettes are shorter than road 11).
Thanks fossy, I may go for the A 1022's
SJS have also now got back to me to say both are decent
Any more thoughts? I'll prob order tomorrow
