Marzocchi Z2 (29) r...
[Closed] Marzocchi Z2 (29) remote lock or conversion kit advice needed
1 Users
Silverfish are seemingly reluctant to answer my enquiries, I have a Z2 Bomber coming my way which came off an ebike and also originally came supplied with a remote lock out.
I need to source a new remote kit for it, I'm not convinced the generic ebay types will work as isn't the compression damping on the Z2 an infinite adjust jobbie?
Or is the damper for remote applications a more simple on/off affair instead?
Alternatively I'm up for converting the damper to a standard top-cap lever - does anyone know if this is possible and have part number info?
I'm lead to believe the ebike Z2 has thicker stanchions than the non-ebike version so my concern is that its damper internals are a different fit to the std Z2, which may limit my options
Posted : 23/03/2021 5:36 pm
