Marzocchi 66 RC3 Ti...
[Closed] Marzocchi 66 RC3 Ti - Top Out Clonk
4 Users
Hi All,
I just fitted some new 2012 66 RC3 Ti's to a new frame and had a first ride around - when I pull up on the bars to get the front wheel off the ground there is a bit of a top out clonk from the forks, I don't get it on the similar 55's that I have. Is this a normal thing or is there a problem or adj that I should make? I have no preload wound in or Air in the forks at the moment.
Cheers!
Posted : 22/11/2013 6:39 pm
Nope, that's not right. Get 'em back to Windwave under warranty.
I've got a set on my Patriot and don't have that problem. They are a brilliant fork IMHO.
Posted : 22/11/2013 7:06 pm
Same happened to my old DT's and it turned out the damper was stuffed. Changed under warrenty though.
Posted : 22/11/2013 7:41 pm
probably either not enough oil in them or to little rebound damping.
Posted : 22/11/2013 7:51 pm
Hmm doesn't sound good - especially as brand new! I'll contact Windwave direct, cheers all.
Posted : 22/11/2013 8:39 pm
You what? FFS, how hard is it to adjust the rebound damping or add 5cc's of oil!
Posted : 22/11/2013 8:48 pm
David you speak with the least technically capable person in the free world - If I can break it trying to fix it I will. But you are right, I'll confirm the issue with Windwave and then fix it as they advise, I hate working on forks though as I never have the right tools, the time or a clean workspace to get things done well. I'm sure a LBS will be able to sort me out in jiffy if I know what I need doing and its not just a fork adj.
Posted : 25/11/2013 1:54 pm
