Marzocchi 55R forks...
[Closed] Marzocchi 55R forks travel change
3 Users
Hi,
posted up a while ago about changing the travel on my forks to 140mm from 160mm. a link was posted on how to do this. i am going to be doing this tonight, quick question - is there a way of checking which travel option they are set at before stripping them down?
cheers
Posted : 19/10/2010 12:19 pm
measure the stanchions
Posted : 19/10/2010 12:20 pm
would they be measuring what travel they should be or should they measure more?
Posted : 19/10/2010 12:55 pm
The stantions will be showing a couple of mm more than the travel they are giving. When I say showing I mean in between the crown and the lowers.
For example if they are set at 140mm they will be showing about 142(ish)mm same goes for 160mm.
Posted : 19/10/2010 2:42 pm
i have measured them and they are showing 158mm
checked my old judys that are 100mm travel and they are showing 124mm of stanchion
Posted : 19/10/2010 5:09 pm
They are set at 160mm at the moment then
Posted : 19/10/2010 6:48 pm
Take the springs/air out of your judys and compress them I bet they are 120mm travel. A lot of judys had travel spacers that you could move around to adjust the travel on them much like the way you change the travel on Marz forks.
Posted : 20/10/2010 7:38 am
