Marks on crank axle
[Closed] Marks on crank axle
4 Users
Just replaced my bottom bracket bearings and the bearing on one side had corroded to the crank axle. After a spray of WD40 I managed to get the bearing off with a punch but I’ve left some small score maths on the axle, not to mention the mark from the corrosion.
Should I know be concern about the integrity of the axle?
James
Posted : 07/03/2022 10:26 pm
Steel or aluminum ?
Posted : 07/03/2022 10:38 pm
Raceface turbine
Website says alloy spindle
Posted : 07/03/2022 10:41 pm
You can get replacement spindles, if it worries you.
Posted : 07/03/2022 10:46 pm
Ah cheers I didn’t know that.
Do they need replacing if corroded or marked?
Posted : 07/03/2022 10:57 pm
scoring is a non issue imo.
bit of wet and dry, couple of turns around the bearing surface and you'll clean that corrosion staining right off.
Posted : 07/03/2022 11:24 pm
Posted : 08/03/2022 6:59 am
I wouldnt worry at all.
On my CAAD12 the internally routed front mech cable cheese wired my crank axle, over what must have been a fairly long time as its cut quite a groove it in, and its not failed yet.
A bit of minor surface corrosion and scoring wont matter at all. As said, lightly sand it, grease it up and put it back together.
Posted : 08/03/2022 8:20 am
