Manitou Mattock ser...
[Closed] Manitou Mattock servicing advice...
6 Users
Shall I try doing it myself- they take a beating at BPW so I could do regularly if I know what to do. Where do I get the stuff from- is TF tuned the best for bits and advice? Is it easy? I know there’s some special tools I need, but I’m happy to have a go at most jobs.
Posted : 03/07/2019 8:13 am
Anyone?
Posted : 03/07/2019 8:17 pm
There's a massive thread on mtbr with all the info you need and the official Manitou video on YouTube.
Whether it's easy or not is hard to answer. I've serviced blackbox Revs, a Marzocchi 350 and it's no harder than those
Posted : 03/07/2019 8:26 pm
 poah
It is really piss easy to. Make sure you get the latest one piece seals (141-34000). I use supergliss 100k in the lowers.
Posted : 03/07/2019 9:05 pm
Not serviced mine yet but took them apart for a travel change when I first got them - super easy with the (eye wateringly expensive) proper tools.
Posted : 03/07/2019 9:39 pm
I was thinking of making the cassette tool thing myself, a mate has a load of metal working tools, I’ve got the flat socket, and I think I have a small socket and extension. Not sure if it’s thin enough though.
Posted : 03/07/2019 10:38 pm
I'd do a lowers service, if its feeling ok I'd leave it at that. It's easy, you don't need the thinwall socket. An Allen key works fine. I loosen the footbolt with a standard socket then wind it the rest of the way with an Allen key (reverse thread). Only slight issue is reverse torque settings. I have an old spring type torque wrench that just about works.
Posted : 04/07/2019 4:03 am
For some reason I can't edit my post, I misread it as going to BPW. Either way they're pretty easy to work on.
Posted : 04/07/2019 4:09 am
Jamesoz cheers I think I will look for that on YouTube. Will I need a crush washer like on Fox forks?
Posted : 04/07/2019 5:58 am
 poah
No crush washers as they screw into the legs. The newer seals are so much better
Posted : 04/07/2019 12:53 pm
Is it best to get the seals from TFT, or just get the kit from CRC?
Posted : 04/07/2019 7:48 pm
 poah
These are the deals
https://www.chainreactioncycles.com/mobile/manitou-fork-dust-seals/rp-prod174800
Posted : 04/07/2019 7:59 pm
I have a set of the old two part seals that I never got round to using, if anyone is interested just cover postage costs and there yours
Posted : 04/07/2019 9:49 pm
Luke I’ve pmed you-
That would be great thanks!
Posted : 05/07/2019 6:10 am
