Hi! Aluminium frame, rubber/plastic downtube Protector.
Most of it is still stuck very well, but the corners are lifting and it looks tatty. What glue would work and won't damage the frame ?
Silicone sealent? You could wipe the exposed parts down with somehting to clean the edges and the frame (Isopropyl maybe) and then put the silicone under the protector and smear a bit over it as well.
Worst presidential campaign strap line ever!
Thanks willard!
Take the whole thing off, clean with isopropyl alcohol and use 3m vhb tape cut to shape.
I did a ‘temporary’ fix with Sugru on a downtube protector that was starting to peel off several years ago and it’s still going strong
What Kramer said.👍
