Maguya Vyron elect ...
[Closed] Maguya Vyron elect wireless dropper ? Any experiences ?
15 Users
http://www.chainreactioncycles.com/magura-vyron-elect-wireless-dropper-seatpost/rp-prod144485?gs=1&gclid=CjwKEAiA6rrBBRDsrLGM4uTPkWASJADnWZQ4QVzWRJ_X77bbOfqz-831WvYMKyYgZkWoYpqTvaEo7xoCNmTw_wcB&gclsrc=aw.ds
It may be slight overkill to get rid of a dropper because i have some internal cable rattle on the headtube...
But still, it's quite interesting for sure !
Posted : 18/11/2016 2:18 pm
 DrP
A friend has one.
Hmm...I'm not overly impressed - there's a half second delay, the buttons are hard to press, and I don't think it's a miracle improvement over my KS Lev.
I like the response of the cable lever - i push it - i know it's pushed...I let go - I know it's 'off'..
I wouldn't have one if i could have a cable.
DrP
Posted : 18/11/2016 2:20 pm
I had one go saggy on me, this was about 6 months ago, promptly replaced, faultless since.
Posted : 18/11/2016 2:21 pm
Mates try mine, get confused by the delay, you soon get used to it.
Posted : 18/11/2016 2:22 pm
I don't fancy the delay, I think it would annoy me. Then again I may be the only person who can forget to let go of the button on my reverb once it is where I want it 🙄
Posted : 18/11/2016 2:26 pm
Still debating this one, mostly because my dropper is internally routed and causes cable slap out on the trail... obviously this would completly negate any cable rattle issues...
Seems a little excessive though to remove a working post just because of a little rattling.
Posted : 20/12/2016 8:37 am
I had a long term demo bike with one on it.
Great idea, sucks in reality.
The lever/button is literally, junk. It's got 3 buttons, 2 of which are irrelevant & the actual remote button is the size of a small pea & almost impossible to press when moving.
The remote is also held on by what I assume is a Garmin style elastic band so wobble around everywhere.
There is also a slight delay in the post which makes it hard to know if its working or not.
In 2 or 3 versions time, it's probably going to be amazing (with a proper remote). Right now? No way.
There is a wireless Reverb due in the new year...
Posted : 20/12/2016 9:12 am
I have one but I paid less than that for it! I think Merlin were clearing some out when I picked mine up.
It works fine but the delay is a bit of an irritation still. Most annoying is trying to set it to an intermediate height, requiring some kind of hover-arse manoeuvre.
Still, worth it to be able to just switch it between bikes though. Means I can use a dropper on my cx bike.
Would be nice to have a more positive single switch and ditch the electric suspension buttons as well but you can get used to it.
Posted : 20/12/2016 9:15 am
Mine will only fit 1 of my bikes, well, unless i use a 30.9 to 31.6 shim on the Parkwood i guess. But i don't really need the dropper for anything other than the Whyte.
Posted : 20/12/2016 9:32 am
I use a shim with it on the PX XLS. No problem using a proper shim with a seat post anyway.
I'm not sure, if I only wanted it for one bike, if I would bother.
Posted : 20/12/2016 9:37 am
I have one and am quite happy with it. Delay is not an issue. You quickly adapt so I no longer notice it. The stock button is too small, this was easily rectified with a small blob of sugru and is now much better. I love how easy it is to move between bikes. It also has a low stack height compared to a reverb which could be the difference between a 150mm or 125mm drop post for some people.
Posted : 20/12/2016 9:13 pm
Had mine for around six months now and it's been faultless. I think I've only charged it twice!
After a few rides, the delay isn't noticed anymore. I agree with the button thing. I'm even used to that now though (it could have been bigger).
My remote has never wobbled, it's pretty secure. I don't even remove it from the bars when the bike is on the roof. Cursed myself now though obviously! 😆
Best of all, it fits both my Bird Aeris and my Commencal Meta AM hard tail, so it's paid for itself really 🙂
I just pop it on whichever bike I'll be using.
Posted : 20/12/2016 10:14 pm
 StuE
First one of mine lasted less than 2 rides, replacement is fine, soon get used to the slight delay and I also modded the remote with Sugru.
Posted : 23/12/2016 1:26 pm
I have one. The delay is not a problem and not overly noticeable. The button does need to be bigger though. I've painted mine white so it stands out from the other two buttons. I believe Magura are rectifying the button issue.
Posted : 23/12/2016 5:01 pm
Thanks for the info 🙂
Posted : 23/12/2016 5:05 pm
Eek. Now reduced to £250 at merlin. I may have 1 more try at getting rid of cable rattle first.
Posted : 25/12/2016 8:44 am
One more go would be to buy one and ditch the cables 😀
Posted : 25/12/2016 9:54 am
Done
Posted : 25/12/2016 10:11 am
The end of any cable rattle!
Ant+ remote dropper post.
[URL= http://i248.photobucket.com/albums/gg167/weeksy59/WhyteT130SX/IMG_20161231_150940_zpsegirdbec.jp g" target="_blank">http://i248.photobucket.com/albums/gg167/weeksy59/WhyteT130SX/IMG_20161231_150940_zpsegirdbec.jp g"/> [/IMG][/URL]
Just charging up before installing but have tested and works.
Thanks all for the wisdom.
Posted : 31/12/2016 3:19 pm
😀 enjoy. Don't forget the lump of sugru on the button.
Posted : 03/01/2017 12:06 pm
Wirelsee you ssayyy
Posted : 03/01/2017 12:34 pm
Found some info on the remote tweaks for a better button. See https://www.bikerumor.com/2016/11/23/dropper-post-roundup-comparing-crankbrothers-highline-magura-vyron-raceface-turbine-rockshox-reverb/
there is a picture of a sleeve in the Magura section
Posted : 03/01/2017 1:38 pm
@nixie - any pictures of your button mod, or any advice as to how big a blob to go for ?
Until of course that sleeve is available in the UK.
Posted : 04/01/2017 9:02 am
I can wait a while for the sleeve thing 🙂
I'm not a massive user of the dropper anyway myself, usually only at trailcentres and it's up or down, not up-down-up-down-up etc.
Posted : 04/01/2017 9:12 am
@Trimix, I'll sort a picture later on when i finish changing the bars on that bike.
Posted : 04/01/2017 4:21 pm
So long term reviews of the post? How are they holding up? I have broken my second reverb in almost as many months. I am bloody sick of them and the warranty claim is taking time due to Christmas closure. Trouble is I have no idea what to go for next as I want another 150 drop. But I want one that is reliable!
Posted : 04/01/2017 5:58 pm
Had mine for about 4-5 months - works fine.
Ride about 3-4 times a week normally and use it every ride.
Charged it once in that time.
Posted : 04/01/2017 8:40 pm
[url= https://c5.staticflickr.com/1/378/31730203020_d0c7e7fa28_c.jp g" target="_blank">https://c5.staticflickr.com/1/378/31730203020_d0c7e7fa28_c.jp g"/> [/img][/url][url= https://flic.kr/p/QkTzTS ]IMG_20170104_192054736[/url] by [url= https://www.flickr.com/photos/27324215@N02/ ]nixie_me[/url], on Flickr
Here's the sugru mod. It's not big, small pea sized.
Had mine 3 or 4 months and been fine so far. Only charged once in that time.
Posted : 04/01/2017 8:49 pm
Err, no you're not...
Posted : 04/01/2017 8:51 pm
Cheers Nixie, I shall do the same to mine, until that sleeve thing is available.
There have been a couple of times when wearing long finger gloves that I've missed the small button and gone over a drop saddle up !
Posted : 05/01/2017 8:40 am
Must admit, it's a bit weird having the pause, but not a major issue. I had the button too far from my thumb so have moved it closer now.
Very happy though, works really well
Posted : 07/01/2017 6:53 pm
I've been through three in 8 months Inc one pre prod. Have to admit, I found it the most hateful thing I've ever put on a bike. Unreliable, rubbish remote and I never found the delay/predefined length of time the port is open anything other than frustrating... lent them to a couple of mates in that time who found the same. No longer on any bikes of mine!
Posted : 07/01/2017 7:19 pm
Err, I realise in the grand scheme of things, my last post was pretty unhelpful - sorry!
Posted : 07/01/2017 7:47 pm
Not at all, all info good and bad is welcome.
Posted : 07/01/2017 7:56 pm
