Hey all,
Looking to match up MT7's and a OneUp dropper. Is the way to do this to order an MT7 adaper for a drive chain, say I-Spec, then order the dropper with I Spec? Seems odd to have Magura brakes, and a OneUp dropper matched with a Shimano adapter but seems to be the way (Using Shaimano as my drivechain and matchmaker on the shifter side is I-Spec).
Thanks
The OneUp lever is SRAM-matchmaker compatible by design, so it can be fitted to a Magura Matchmaker Shiftmate adapter ( https://r2-bike.com/MAGURA-Matchmaker-Shiftmix-left ).
All other bits (clamp, MMX adapter, I-spec) bolt to this SRAM interface, as can be seen on their website: https://www.oneupcomponents.com/products/dropper-post-remote?variant=19542749642849 .
For maximum flexibility I would get the clamped version of the OneUp, that way it should be easier to sell on in the future, or use it in an emergency if for some reason you change brake brands.
Swap the dropper remote for one of these
https://www.wolftoothcomponents.com/products/remote?variant=6004794425379
We've MT5's and one-up via the adaptor above.
Thanks all - wolftooth it is! Worth it for the extra €20 after any adapters. Cheers
