Magura MT2 - separa...
[Closed] Magura MT2 - separating pads
3 Users
I've received a bike which has had the brake caliper removed for transport. The pads are too close together to allow the rotor to fit between them (the gap is maybe 1-2mm). What's the technique to open the gap? It's my first bike with hydraulic disc brakes!
Posted : 09/07/2016 8:13 am
Use something blunt (butter knife or wide flat head screwdriver), put it between the pads and push them outwards so the pistons retract.
Fit the wheel then pull the lever a few times and the pads will then automatically adjust to the correct distance apart.
Posted : 09/07/2016 8:29 am
^that
Next time, use the little plastic wedges that came with the bike it brakes to stop them closing up if you pull a lever.
Posted : 09/07/2016 8:33 am
Thanks, I'll try that. I was worried in case I had to take the cap off the cylinder.
The bike was sent to me without the wedges, so I'll have to buy a set. Presumably any bike shop will have them in stock...
Posted : 09/07/2016 10:14 am
Use any folded cardboard/plastic spacer if you need.
Posted : 09/07/2016 11:15 am
