magicshine MJ 858 g...
[Closed] magicshine MJ 858 go pro mount mod
7 Users
has anyone managed to fit a gopro mount to the above light?
would like to buy one but dont want the curved bar mount..
my google fu is weak and i cant find anything about any mods....
Posted : 13/10/2016 8:04 pm
[url= http://www.valostore.fi/tuote/gopro_kiinnike_lumonite_bx1500_bx2500/ ]This[/url] might do the job assuming the light has a similar flat area on the bottom as most of the other common lights and they will ship to england.
If you know anyone with a 3d printer then [url= http://www.thingiverse.com/thing:903572 ]this[/url] looks like it would also work.
Posted : 13/10/2016 8:33 pm
cheers for that, reckon thatd work just fine..
Posted : 13/10/2016 9:46 pm
can print the one mikeG posted for £5 delivered.
Posted : 13/10/2016 9:59 pm
Yes please! Could I get 2 ? Chris@cranmoreconsulting.com
Posted : 14/10/2016 7:01 am
get these, took a week for mine to be delivered.
http://www.gearbest.com/led-accessories/pp_240917.html?wid=21&siteid=54264&utm_source=webgains&utm_campaign=GearbestUK
Posted : 14/10/2016 8:33 am
I 3D printed some for a few people, seemed to work fine.
Posted : 14/10/2016 8:35 am
I've got the gearbest adaptor (and it works, kinda), but if you can get one 3D printed I'd use that.
Go-Pro mounts work much better when they're made of plastic and can bend a bit, so if you use an aluminium adaptor in an aluminium mount they slip unless you stick some insulating tape between each finger to pad it out.
Posted : 14/10/2016 8:56 am
on the magicshine 902 can the curved bar mount be easily removed?
Posted : 14/10/2016 9:33 am
Under the padding there will be a screw to undo.
Bear in mind you will need to reuse that screw or one of equal length, you don't want to put a 2" screw through the internals.
Posted : 14/10/2016 2:36 pm
cheers...I've found several 3d printed gopro mounts that someone off of here printed for my troutlite that I reckon will bodge on just proper...
Posted : 14/10/2016 7:00 pm
