Who else thinks that roots have a magic ability to ruin a ride?
I've got a near permanent fear that as soon as it becomes slightly damp any touch of rubber on wood will have me on my backside quicker than quick.
I'm sure this is partly unfounded but I seem to be super cautious and need to overcome this stupid fear.
Anyone got any suggestions / advice?
I attack them in a positive manner, unweight the front wheel slightly with a jedi taught push, and then throw myself into a nearby bush. If there's a choice of bushes, then I go for the prickliest one within reach.
roots are trigonometry fascists - you have to hit every single one at an exact 90 degrees or they push you off
ride them, then ride them, then ride them some more 😆
local trails for me are Mugdock, much of which is root fest - those of us who ride there a lot get the hang of the roots, although they still do throw us in the bushes a lot ! Very noticeable though if we get some folks out who are not used to roots, they see even more of the bushes !
hit them squeare on, bike upright, unweighted....hope for the best 😛
Jonv - I've tried the push and tumble technique myself a number of times...
I'm also really good at the front wheel wash out and face plant on the hardest object I can find.
Weight off the front, ride square if poss.
Fwiw, I dislike wet roots too.
I love all the advice about hitting roots square on - come ride around my neck of the woods and you'll see that you frequently have no choice in the matter! 😉
ride square [b]if poss[/b]
Yeah, if you've got one root you can do it at right angles, but they don't generally run parallel and they hunt in packs.
Seek out better roots- slippery inners roots are proper asbo material but cultured, gentlemanly Drumlanrig roots or sophisticated french tarantaise roots are not so quick to maim you. (other good guy roots are available) Then once you've built up some trust and confidence with those, go and hurt yourself on the slippery ones.
One technique for avoiding wet roots is.... only ride when it's dry 🙂
Another which works for me is popping a small manual over them. Or when they're off camber, go in high.
One benefit of riding with flats is it's easier to dab through them too!
Lay off the brakes if you can. Try to keep a bit of speed on the approach to a rooty section - Attack position - weight back, arms loose, pedals at quarter to 3 and heels down a bit. Try to unweight the bike and float it rather than drive the front end through the roots which will only end in tears.
Get some sticky tyres. Float light over them.
Go night riding all winter, when the spring comes and daylight returns you will finally see what you have been riding over and be amazed.
Stop looking at them, look beyond them.
yup, go for as square on as possible, lift up and unweight bike. Some of the ones in the woods I ride are at funny old angles which makes it interesting. Also go as fast as possible so there's no time to slip up. I did get caught by one sometime ago though, the slippery snake was hiding in the grass, I was on the deck in an instant 😐
There's an excellent diagonal root that catches an awful lot of victims here - it's on a narrow straight-ish off-camber bit of fairly flat singletrack and it runs with the camber. You've rarely got the speed to hop it, it's on a clay on chalk mix and if it does catch you then it tends to slide your front or rear tyre into some pretty solid foliage which stops you dead. One's natural inclination is to take it high and expect to get knocked a bit off line but then it's easy to catch your bar on some tree trunks on the high side. So many different ways to crash!
I love riding rooty trails. Just lift the front wheel over and it matters not a jot what the back wheel is doing.
I love riding roots! The wetter the better! 😈 All the above advice is good. I think speed really is your friend when riding the things. It does take a bit of courage and you have to try and stay loose so you can react if the front wheel does start to slip sideways.
Some good advice above. I'd add if the roots are proper gnarly, just give up and pretend they aren't there. Works wonders!
True, that.
With the right tyres they're a very fun challenge. If I'm fortunate enough to have something like a Hans Dampf on, they're good fun!
Generally you should be thinking about what's after the roots rather than the roots themselves – I generally try to unweight the bike and focus on the half decent bit of trail ahead of them where I can plant/chuck the bike into.
Another one I find is that if you can ride them higher up and closer to the base of the trunk where they're wider then that helps. Generally it's not the tread that slips but if you get enough root in contact with the tyre carcass. So the narrower the root, the more likely it is to get between the nobbles and slide on the carcass. Baring that in mind, I find tyres with a more MX style tread pattern (Blue Groove, Hans Dampf) tend to go better on roots as there are less horizontal lines/gaps all the way along the tread.
Obv 90 degrees if possible but not always possible.
speed is you friend, brakes are your enemy and unweight the bike as much as possible.
Pretty much what I would say. Stay loose and ride it out too!
STW. I am VERY disappointed 😉
I'm very much in the "need to see it to learn it" camp so I suggest you find some riders you can ride with / watch to understand how it's done and see that it's not as difficult as you think.
Bunny-hop over them and don't touch the brakes. Even if you do touch them and your wheels slide out a wee bit, your forward momentum will snap the bike back in line........ most of the time.
I'm also a big fan of unweighting the bike. I get off it and push it across em.
+1
You're only sliding while you're on the roots, if you're only there for a split second you'll not slide enough to get into trouble.
Or quarter past nine if it's morning.
Jump Them!
I think speed is the key - its the off camber ones or the root gardens which throw me.
Cheers for the tips.
riding wet roots is like riding wet limestone. You can guarantee that your wheels will not end up where you wanted them to be.
The trick is to accept that the bike will move under you and plan where you will slide in such a way that your wheels will catch at some point.
That and hitting them square where possible. With those two techniques, you should have it right two thirds of the time. The other third is made up of blind luck with splashes of brute force and ignorance.
Large volume tyres at a lower pressure to deform around the roots and be out of contact with dirt for less time. The compromise is slower rolling and less direct handling.
Taking a good line really helps. Look ahead for helpful patterns like meeting diagonals and hard edges that will stop a slide and plan your route through, then look into the distance, stay on the power and keep loose.
Isn't there a STW thread "What tyres for wet roots?". If not, why not?
Line, practice & confidence. Roots need to be treated with respect not fear. Get the front through - over if possible and back down then when the back steps out relax and keep going, it will step back into line.
+1 for unweight, or just anticipate which way you're going to slide and go with it.
Not wishing to sound like a gear-freak but tyre choice is quite significant here too. If you have lots of wet roots or rocks it may be worth sacrificing mud performance to go with something with finer stickier tread.
Tyre choice is ballcocks. Hit a wet root wrong and I don't care what tyre you've got on. I love the idiot advice about clearing one root. Most often there's a series of them in varying directions. Get the front over one and yes the back may follow until you hit the next.
If tyre choice is so important, how is it I know several CX riders who run near slicks over the whole winter?
You either get it or you don't.
As said previously, your biggest problem is fear. That's not anything you'll get help with here, you have to sort it yourself.
Also, ignore additional idiot advice to go faster. Speed is never your friend if you're low on skill. The faster you go, the more it will hurt if something goes wrong.
Steady with confidence, light and positive. Look at the way in and then the way out. Never look at something you're trying to avoid... You'll hit it! Practice again and again.
I do wonder about tyre and tyre pressure choices - if the root is smooth and wet surely this is akin to what tyre for ice 😉
gears_suck has spoken the rest of us are idiots thread closed! 😀
It's not bollocks at all. Wet roots are one of the most difficult things for tyres, and the type of rubber has a significant effect.
You talk as if I've never ridden wet roots in 20 years of MTBing. I wish that were the case 🙂 I've ridden a lot of roots, with a lot of different tyres, and it makes a difference. As to why CX riders run slicks, well I have no idea. They're weirdos. Perhaps it's because they like to run carrying their bike.
