As I'm a complete numpty I've managed to lose the pad axle from the rear break. The part code according to the tech docs is Y8JZ98010 but I can't find one on the net. I've mailed Madison but no reply as yet and it means I'm bikeless till I get one sorted!
Any ideas?
A big split pin is about your only option if you can't find a replacement (that's what they supply for Deore brakes anyway, so it does work quite well).
Can anyone point me in the right direction, not sure what I need?
Cheers.
[img] http://cdn.priceprobe.net/i/7194335.24744df9aa87485a77.06074638 [/img]
Something like that. Not quite sure on the size.
Your LBS might have something lying about...
You could go to your LBS and ask them to order part # 8JZ 9801 from Madison. It's a carriage free item so the shop won't need to wait until they have a minimum order before placing then order. However, the part is currently out of stock and there is no due date.
Don't you get a new one if you buy a set of pads?
LBS, if only there was one of those round here that I had any faith in. Out of curiosity, how do you know they are out of stock?
I logged into Madison's B2B site and checked.
Fair do's, I have managed to find one on a German site (bicikli.de), if Madison don't come back with anything tomorrow I might have to order through them, not keen on bodging it.
Thanks again.
