Halfords or Screwfix or A. N. Other?
As in brass countersunk washers?
Sorry, no, as in stainless steel hex 15mm bolts (countersunk), and plain brass washers because I'm a tart.
To mount one of these in order to fit two bottles in available space. Need longer bolts than it came with.
The washers are when it's not fitted.
Check availability in local stores, reserve/order online if possible, collect.
Thanks, I was just being lazy.
M4 ?
Are bottle mounts not M5? (Goes to check)
Countersunk...does not need washer?
Confused.
You'll need M5 screws to mount it to the frame.
Where do you want to put the washers?
These are what's going in the (bamboo) frame. Mind playing tricks now but pretty sure it's M4 (left them at home). Will get both.
M5 it was, 16mm was enough and Toolstation good.
[url= https://i.postimg.cc/SssNHHJn/PXL-20240428-121123681.jp g" target="_blank">https://i.postimg.cc/SssNHHJn/PXL-20240428-121123681.jp g"/> [/img][/url]
You might be asking why not strap it in the same way as the one on the seat tube. To which I can only respond, yes, but aesthetics innit. Used some of those screw-in inserts before which worked for a few years. I'll be happy if the frame makes it until 2026 which'll be ten years of much use and abuse.
Show us the bike then, looks interesting.
An early incarnation
[url= https://i.postimg.cc/xdfp4FwN/20170417-145653.jp g" target="_blank">https://i.postimg.cc/xdfp4FwN/20170417-145653.jp g"/> [/img][/url]
Last summer
[url= https://i.postimg.cc/KYcpggQT/1690045130646.jp g" target="_blank">https://i.postimg.cc/KYcpggQT/1690045130646.jp g"/> [/img][/url]
Did you swap out the seatpost??
Yep. The seat tube cracked a couple of years ago and while it was fine in a fibrefix bandage, I eventually worked up the courage to cut it out completely and bond a cf tube in. And it worked! Well, there's things I'd do differently if I had to again but so far no shards in my arse and the ride is as smooth as before so call that a win.
