Lyrik Torque Cap Pr...
[Closed] Lyrik Torque Cap Pro4 Confusuon.
6 Users
I've just fitted some 2017 Lyrics with standard spacing Hope Pro4 hubs, I noticed the dropout flange bit looks wider, do I need to swap out the 15mm caps for torque caps or will it be fine with the old style 15mm's? it all snugs up ok.
Posted : 28/05/2017 10:57 am
You'll be fine with the normal 15mm caps. The torque caps just make fitting the wheel a bit easier as they centre the hub in the dropout better
Posted : 28/05/2017 11:09 am
I'm on bog standard 15mm spacers with Pro4/Lyriks.
All works fine.
Posted : 28/05/2017 11:46 am
Torque caps make fitting wheel easier, do they increase stiffness, probably, but not that anyone can honestly notice!
Posted : 30/05/2017 8:43 am
If only there was a wider stiffer axle standard they could have used, eh?
Posted : 30/05/2017 8:48 am
Ha - George - yes 20mm !
Anyway [url= http://www.hopetech.com/industry-non-standards/ ]Hope make torque cap spacers now.[/url]
Posted : 30/05/2017 9:07 am
Boost 150x40?
Posted : 30/05/2017 9:08 am
