lowest stack height...
[Closed] lowest stack height h/set and stem
3 Users
Hi I need a trad 11/8 h/set but with a low stack height and a stem which has the least amount of steerer tube insert, most are 40mm i need 30 to 35 mm o/s clamp thankyou
Posted : 14/06/2011 12:28 am
headsets: www.singletrackworld.com/forum/topic/what-headset-is-lower-stack-height-than-and-fsa-orbit
so basically an xl2 is low or a directset if you're desperate.
stems - depends how long you need. some dh/bmxy ones are 25mm but for more trail type fsa, truvativ are two though there are several at around 35mm
Posted : 14/06/2011 6:02 am
Sunline V1 stems are about 34mm
Posted : 14/06/2011 6:36 am
