Low stack stem for ...
[Closed] Low stack stem for 35mm bars
12 Users
I’m after a low stack stem for 35mm diameter bars, what’s out there?
Stack height less than 40mm needed.
Posted : 28/05/2019 3:30 pm
Looks like they only have 45mm length at CRC but the Funn Funnduro is what i use, stack hight is 32mm.
Posted : 28/05/2019 3:50 pm
DMR do a low stack one I think.
Called the Defy 35+
Posted : 28/05/2019 4:04 pm
Deity Copperhead
Race face turbine 35. Stack is 40mm and it’s really nicely finished and pretty light
Posted : 28/05/2019 4:35 pm
The Renthal Apex I have has a 40mm stack, I need something more like 30/35mm stack height.
Thanks for all your suggestions.
Posted : 28/05/2019 4:45 pm
I was going to suggest the DMR Defy
I put one on my fs build and had to cut the steerer down
Posted : 28/05/2019 4:49 pm
DMR one did the trick for me on a friend's comically short steerer.
Posted : 28/05/2019 5:10 pm
Aren't most stems ~40mm stack?
I needed a proper low stack for 26mm steerer. Current generation dmr defy is 27mm so perfect for me. Prior generation (the one on sale) was bigger at 30ish.
Ordered mine off wiggle
No sign of dispatch yet though!
Posted : 28/05/2019 5:14 pm
I’ve got an orange Funnduro for 35mm bars (35mm length) if you are interested
Posted : 28/05/2019 5:22 pm
I’ve ordered a DMR Defy stem, it looks exactly what I need.
Posted : 28/05/2019 6:45 pm
Came to say DMR. Good job !
Posted : 28/05/2019 7:11 pm
Ragley stubbing fits the bill too.
Posted : 28/05/2019 9:20 pm
As above, DMR Defy is a nice low stack height.
Also the Funn Funnduro is available in 35mm and has a stack height of 28mm.
We all need to stop cutting our steerers so short. I should have learned by now...measure the right length, then a add 20mm or so. Much better in the long run!
Posted : 28/05/2019 10:39 pm
