Low stack but comfo...
[Closed] Low stack but comfortable saddle
9 Users
I'm looking for a comfortable saddle with low "stack height". I can't drop my post any further, would like to keep this post but would ideally like the saddle top about 1-2cm lower than it currently is when the post is fully extended.
My current saddle is a charge spoon and quite like the shape.
Any suggestions (about the saddle) welcome.
Posted : 14/05/2016 9:10 pm
Selle Italia SLR 135 is one of the most comfortable saddles I've used, but is too expensive expensive when my bike inevitably goes bouncing down a hillside.
Posted : 14/05/2016 9:17 pm
cut 1-2cm off the bottom of the post?
Posted : 14/05/2016 9:26 pm
It's a reverb so cutting is out unfortunately.
Posted : 14/05/2016 10:09 pm
Shorter cranks.
Posted : 14/05/2016 10:12 pm
Only gains me 5mm, plus I would have assumed a saddle to be cheaper than cranks
Posted : 14/05/2016 10:14 pm
I've got a few saddles can you measure the spoon and I'll try and measure the ones I've got.
Posted : 14/05/2016 10:19 pm
Don't know how this compares in stack height.
Seller Italia SLR max gel flow, more comfortable than a comfortable thing..
http://www.chainreactioncycles.com/mobile/selle-italia-slr-max-gel-flow-saddle/rp-prod82179
Posted : 14/05/2016 10:43 pm
Thicker pedals. Or some platform shoes.
Could you trim the seat tube down? L
Posted : 14/05/2016 10:50 pm
Thanks everyone so far. Wiggles, I'll measure up tomorrow. Thanks also for the slr suggestion, I'll have a look.
Posted : 14/05/2016 10:57 pm
I went from a charge spoon to a fabric Scoop and I've no idea whether there was much stack difference in the standard model but I note that they now do a fabric Scoop shallow model - so that may be worth a look. If they're anything like the standard sccop it will be very comfortable coming from a spoon.
Posted : 14/05/2016 11:06 pm
The Brooks Cambium has a very low height as it 'hammocks' in the middle as you weight it. I've just removed one and had to drop by 15mm to compensate for the taller replacement!
Posted : 15/05/2016 7:32 am
