Low flow cold tap.
[Closed] Low flow cold tap.
6 Users
On the bath only not the basin.
Leak? Or faulty tap?
Posted : 19/10/2017 8:14 pm
I've got that too!
Posted : 19/10/2017 8:16 pm
Race you to an answer!
If some kind soul could report bike forumage as per usual that would be great.
Posted : 19/10/2017 8:17 pm
Bits inside the valve bit reducing flow?
Take it apart and have a look.
If it was a leak, there would be a leak.
Posted : 19/10/2017 8:34 pm
has it always been like this or just started being like this? I had a tap with poor flow - it was a bit of debris in the pipe from when it was plumbed in. Other option is a failing valve
Posted : 19/10/2017 8:42 pm
What type of tap is it ?
Ceramic cartridge quarter turn or tradition multiturn ?
Posted : 19/10/2017 8:51 pm
A gold one. 😀
Multiturn.
I'll attack it with tools tomorrow.
I hope it means i have to replace the whole chuffing bathroom.
Anything to get out of decorating
Posted : 19/10/2017 9:51 pm
Take the top of the tap off and check the washer.
Check for any isolation valves down stream that might have been left in a partially closed position.
Posted : 20/10/2017 11:46 am
does it have a tap flow regulator? are you in a hard water area
remove regulator and clean/replace as required
Posted : 20/10/2017 11:53 am
A gold one.
forgot to say........this is clearly your problem !
Posted : 20/10/2017 12:10 pm
