Loving SS but advic...
[Closed] Loving SS but advice on traction
22 Users
Wet wet wet ground today..took the singlespeed out for a blat with mates.
Only prob I had was one of putting power down to the ground - tyre slipping ( 2.1 Bonty Mud X's). I let air out which improved things - only to have a pinch flat later on.
I'm tempted to run a wider tyre - aka the Maxxis Minion 2.35 ( recc'd by a mate).
Any thoughts ?
..stands by for 'yeah add gears quips!'
Posted : 05/12/2012 7:40 pm
The best thing I found on the SS for grip was a child seat on the back and a 2 year old. Surprisingly still let me climb as easily (difficultly) as normal but with a LOAD of grip!
Posted : 05/12/2012 7:42 pm
No No No....
Posted : 05/12/2012 7:44 pm
Climb faster.
Posted : 05/12/2012 7:45 pm
I assume you've fitted a 2.0"(?) Bonty Mud X to deal with mud.
afaik Minions are the dry/loose downhill tread (HR for loam, swampthing for mud, wet scream for filth) and not especially spaced out tread so could block up more easily
For more volume but similar(ish) mud ability/rolling I'd be looking at a Spesh Storm 2.0"
Posted : 05/12/2012 7:49 pm
just keep riding! 😀
I think I used to haul on the bars whilst sort of leaning my weight back to keep the back wheel dug in (easier to do than to type about it!) but now I don't really think about it much. And yet I have a old half-worn intense system 2 (intermediate-to-summer 2.0" tyre) on the back of my singlespeed. Spat it's traction once or twice in the woods the other day but not much more than the mud x on my geared bike does tbh.
[edit] glupton is right too: the more you carry your speed into the gloopy or steep sharp bits, the less often you lose traction. Perhaps fitness and speed-carrying skillz are why it seems easier than when I first had a singlespeed.
It's all about where you put your weight... get that right and traction really isn't a problem 😉
Seriously though... practice and then practice some more, you'll get it in the end and you'll wonder what all the fuss was about (and have a big grin too) 😀
Posted : 05/12/2012 8:07 pm
Put your weight over the back, surely nothing much grippier than a mudx in current conditions...
Edit: beaten to it by graham.. ^
Posted : 05/12/2012 8:09 pm
+1
Posted : 05/12/2012 8:49 pm
I find putting my weight through my thumb for a split second helps no end 😉
Posted : 05/12/2012 9:40 pm
+2
that and learning how to deliver power with nice even torque at low rpm, you'd be surprised what even a summer tyre can make it up with both of the above nailed, should be easy with a mud x 😉
Posted : 05/12/2012 9:53 pm
This +1
Climbs are rarely constant (as you found by losing traction in places), the trick is to pedal much much harder whilst there is grip (usually the flatter bits), then ease off on the bad bits (usually the steep muddy bits).
That and weight shifts and pedaling smoothly. All of which you'll pick up with time.
Posted : 05/12/2012 11:13 pm
 D0NK
What they said ^^^^ Technique. Keep your arse back weight low and pull back (not up) on the bars. Works for me but ymmv
Posted : 05/12/2012 11:22 pm
As above, pedal smoothly and distribute your weight better. If your back wheel is spinning out try pushing your weight back a little, but not so much that your front wheel starts to lift.
29er ss = more grip
Posted : 06/12/2012 6:01 am
Not really, Minion is the great all rounder of the bunch. If it's so sloppy that your trudging through 6+ inches of mud all over the place ride somewhere else.
Posted : 06/12/2012 6:06 am
Get fitter?
The stronger your legs the better you will be able to control cadence...
Posted : 06/12/2012 6:31 am
All about putting your weight in the right place. Standing up and leaning forward to get the power down is NOT the way to go. Sitting down or hovering over the saddle works really well.
Posted : 06/12/2012 6:54 am
 Sam
Weight distribution is key as above, I find shifting back at the start of the pedal stroke then easing forward through it helps get that initial bit and prevents lifting the front wheel as can happen if you keep your weight back. So you end up with a slight rocking back and forth motion. Another option could also be to fit a bit lower gear to help smooth out the torque.
Posted : 06/12/2012 6:56 am
After many years of SS ambling, I've found a wobbly chainring & clipless pedals help for SS, helps smooth out the power transfer.
Some good advice re: technique above. Above that, pick your line well ahead.
And 29" wheels do grip betterer. 🙂
[url= http://farm8.staticflickr.com/7056/6928674149_84b6988920_z.jp g" target="_blank">http://farm8.staticflickr.com/7056/6928674149_84b6988920_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/takisawa2/6928674149/ ]IMAG0335[/url] by [url= http://www.flickr.com/people/takisawa2/ ]pten2106[/url], on Flickr
Posted : 06/12/2012 7:07 am
I know that problem and it's the main reason I gave up on singlespeed. While it was okay for 24s and weekends in the mountains, the local clay was a problem.
Steep slimy climb. Get out of saddle and loose traction or sit down and really struggle. Walking isn't an option.
Green slime covered chalk and icy slopes? no problem with a granny.
Posted : 06/12/2012 7:12 am
Get an extra cog with an extra tooth on and ride it through winter.
Little slower but a bit easier on the ups.
Posted : 06/12/2012 7:51 am
Technique certainly helps but there's stuff that's a scrabbly, grunting mess to climb on an SS and is much more pleasant with gears, I guess depends where you ride but thankfully there's not much of that sort of climb on my usual routes.
Posted : 06/12/2012 8:01 am
