Loose straight pull...
[Closed] Loose straight pull spokes!!!
6 Users
Got a pair of specialized roval wheels, and given them a good 12 months of hammer all round the lakes, in the peaks and local gnar. Spoke tension has gone on a few rear spokes (I'm on 150mm out back), and had to have one replaced. Now 2 more have gone. They just spin in the frigin hub. Am I missing something? J bend spokes don't do that yeh yeh. What do you do with your fancy wheels then? Advice please. I don't intend on buying new wheels until I get a new bike with big wheels ( exact size to be decided), which is a long way off ( I hope).
Posted : 29/08/2014 4:58 pm
Hold them with a pair of pliers. Cover jaws with electrical tape first.
However your nipples have probably seized, so you'll be cutting the spokes.
Posted : 29/08/2014 4:59 pm
You can buy spoke gripper things to stop them spinning whilst you tighten the nipples.
Posted : 29/08/2014 5:00 pm
wwaswas tell me more about the spoke gripper thing. njee20 you may be right! They have a fancy dt Swiss spoke lock thing going on (prob locktight)
Posted : 29/08/2014 5:26 pm
I did as wwaswas said. Took the tyre and rim tape off and added some wd40 to the nipples to help a couple of slightly seized ones.
Posted : 29/08/2014 5:33 pm
Did a search for spoke grippers and they're pricey. I'd go for the flat pliers with tape approach for a one off.
Posted : 29/08/2014 6:17 pm
Park do DT swiss funny spoke key and flat spoke grippers for about £8 each on Ebay
Posted : 29/08/2014 7:21 pm
Any chance of a link suburbanreuben, that eBay search is bringing up notning
Posted : 29/08/2014 8:09 pm
I'm guessing the op has round spokes that are spinning. Personal is use some pliers carefully but as above prob stuck in place
Posted : 29/08/2014 8:21 pm
Was gonna say, seen bladed spoke holders - the Bontrager key ring one is nice, but not seen a tool for holding flat straight pull spokes?
Posted : 29/08/2014 8:23 pm
Here you go. I bought mine off this fella.Nice quick delivery!
http://www.ebay.co.uk/itm/360960051936?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.co.uk/itm/291035290268?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Though they're cheaper here:
http://www.sjscycles.co.uk/park-tool-bsh4c-bladed-spoke-holder-prod24916/
http://www.sjscycles.co.uk/park-tool-sw5-spoke-wrench-for-dt-swiss-torx-spline-prod29455/
SJS also have cheaper options...
Posted : 29/08/2014 8:50 pm
They're for bladed spokes, not straight pull.
Posted : 29/08/2014 9:07 pm
Poo, yes mine are just plain old round spokes. Why the f##k don't they have a square/hex end at the bloody hub? A loose spoke on a expensive wheel set can't make it a right off'?
Posted : 29/08/2014 9:53 pm
At worse a new spoke and nipple so only a few pounds
You can try adding tension to the spoke by bending it while turning the nipple
Posted : 30/08/2014 6:28 am
