Loose fitting 26" t...
[Closed] Loose fitting 26" tyre recommendations
7 Users
Any suggestions for a good general purpose rear tyre with durable sidewalls in 26" about 2.25" or so wide that will fit easily? I've given up trying to fit a new Maxxis Ardent TR. Even if I do get it on the rim. it will probably be impossible to fix a puncture while on a ride. I use inner tubes so there's no benefit in having a tyre so tight.
Posted : 10/09/2018 11:41 am
Ha! Was about to say Maxxis. Always found them easier than others.
Older Ardents, crossmarks, advantages etc see no bother.
Posted : 10/09/2018 12:13 pm
On one's Chunky Monkey (2.4) and Smorgasbord (2.25) are a loose fit. They're usually cheap. They're quite good (in 26er flavour) if a touch draggy.
Posted : 10/09/2018 12:36 pm
I always find Specialized tyres pretty easy to get on & off.
Something like a Purgatory might fit the bill if you can find one in 26.
Posted : 10/09/2018 12:40 pm
 cnud
Do not look at Schwalbe super gravity. Broken tyre lever tight !
Posted : 10/09/2018 12:42 pm
On one smogasbord was quite loose on both 26” rims I’ve tried it on - an old school Mavic d521 and a wtb st i25. Ran it with a tube on the Mavic and it’s running tubeless on the wtb. Definitely better tubeless - has slightly better grip and it’s avoided all pinch punctures so far. Had 2 pinch punctures when running tubes in it. Not a bad tyre for the price though - to me it doesn’t seem draggy but then I run a 2.3 dhr2 on the fs bike (which in itself is probably 4lbs heavier than my hardtail) most of the year.
Posted : 10/09/2018 12:53 pm
I too was about to say Maxxis, I've always found them to be on the edge of "too baggy". Might be your rim?
Posted : 10/09/2018 1:59 pm
Thanks for the replies. Old Maxxis tyres were fine but they all now seem to be TR, which appears to be same as the old LUST. Smorgasbord is a possibility. The Enduro version would be best for the rear because of the harder compound but the website now only lists the Trail Extreme. Specialized is another possibility. I'm replacing a The Captain Control which has a split in the sidewall but the The Captain (stupid name) isn't made any more. A Slaughter might be a good choice but I can only find them with the Control casing, which has shown itself to be inadequate for me. Maybe a Purgatory would work.
I was really hoping that someone might suggest something other than Maxxis, On-One or Specialized.
Posted : 10/09/2018 2:00 pm
